Arguments for the getObjectsByType method require the object name to be passed in verbatim. So replace the _ with :. Here's what I would try:
# get objects
objects = workspace.getObjectsByType('ZoneVentilation:DesignFlowRate'.to_IddObjectType) #array
# DO STUFF
if not objects.empty?
objects.each do |object|
puts 'Setting schedule for : #{object.getString(0)}'
object.setString(2, schedule)
end
end
Arguments for the getObjectsByType method require the object name to be passed in verbatim. So replace the _ with :. Here's what I would try:.
# get objects
# DO STUFF
end
end
Arguments for the getObjectsByType method require need to use the EnergyPlus object name to be passed in verbatim. So replace the _ with :.
Arguments for the getObjectsByType method need to use the EnergyPlus object name verbatim. So replace the
Replace _ with :.
