@kyle benne is working on enabling the CentralHeatPumpSystem in the tertiary loops branch of the OpenStudio repository. The object is available in the OS API, but doesn't work yet, i.e.
chps = OpenStudio::Model::CentralHeatPumpSystem.new(model)
uninitialized constant OpenStudio::Model::CentralHeatPumpSystem (NameError)
For a project of ours involving reversing chillers, thermal energy storage, and HX with a ground source and water source, the MEP designers modeled the central plant in TRNSYS and determined the annual heating and cooling efficiencies.
As a simplification we used an electric BoilerHotWater and ChillerElectricEIR for the central plant and used the COPs from the TRNSYS model for the Nominal Thermal Efficiency and Reference COP fields.
This approach required changing the Energy+.idd
file installed with OS to allow boiler efficiencies greater than unity along with an EP measure to set this value.
For a project of ours involving reversing chillers, thermal energy storage, and HX with a ground source geo field, and water source, main HX, the MEP designers modeled the central plant in TRNSYS and determined the annual heating and cooling efficiencies.
@kyle benne is working on enabling the CentralHeatPumpSystem this in the tertiary loops branch of OpenStudio.
Since the OpenStudio repository. The CentralHeatPumpSystem object is is not available in the OS API, but doesn't work yet, i.e.
For API yet we've been using a project of ours involving simplification for a very complex and innovative central plant that includes reversing chillers, thermal energy storage, and a geo field, and water main HX, HX.
In our case, the MEP designers designer modeled the central plant in TRNSYS TNRSYS and determined that the annual total system efficiency was COP-3.7 for heating and cooling efficiencies.
As a COP-37.7 for cooling. Our simplification we used an electric BoilerHotWater and ChillerElectricEIR for involves altering the central plant and used the COPs from the TRNSYS model for the Nominal Thermal Efficiency and Reference COP fields.
Energy+.idd file installed with OS to allow boiler efficiencies a thermal efficiency greater than unity along with an EP measure to set this value.the boiler efficiency.
@kyle benne is working on this in the tertiary loops branch of OpenStudio.
Since the CentralHeatPumpSystem object is not available in the OS API yet we've been using a simplification for a very complex and innovative central plant that includes reversing chillers, thermal energy storage, and a water main HX.
In our case, the MEP designer modeled the central plant in TNRSYS Transys and determined that the total system efficiency was COP-3.7 for heating and COP-37.7 for cooling. Our simplification involves altering the Energy+.idd file installed with OS to allow a thermal efficiency greater than unity along with an EP measure to set the boiler efficiency.
Since the CentralHeatPumpSystem object is not available in the OS API yet we've been using We've used a simplification for a very complex and innovative central plant that includes reversing chillers, thermal energy storage, and a water main HX.
In our case, chillers by changing the MEP designer modeled EnergyPlus IDD file included with the central plant in Transys and determined that the total system efficiency was COP-3.7 for heating and COP-37.7 for cooling. Our simplification involves altering the Energy+.idd file installed with OS install (*) to allow a thermal efficiency greater than electric boiler efficiencies above unity along with an EP measure to set the boiler efficiency. efficiency to account for overall system COP/EER.
In our case, the central plant was modeled by the MEP designer in Transys with total cooling efficiency of ~38 COP and heating efficiency of ~5.5 COP.
(*) C:\Program Files\OpenStudio 1.10.3\share\openstudio\EnergyPlusV8-4-0\Energy+.idd)
We've used a simplification for a very complex and innovative central plant that includes reversing chillers by changing the EnergyPlus IDD file included with the OS install (*) (1) to allow electric boiler efficiencies above unity along with an EP measure to set the boiler efficiency to account for overall system COP/EER.
(*) (1) C:\Program Files\OpenStudio 1.10.3\share\openstudio\EnergyPlusV8-4-0\Energy+.idd)
We've used a simplification for a very complex and innovative central plant that includes reversing chillers by changing the EnergyPlus IDD file included with the OS install (1) (C:\Program Files\OpenStudio 1.10.3\share\openstudio\EnergyPlusV8-4-0\Energy+.idd) to allow electric boiler efficiencies above unity along with an EP measure to set the boiler efficiency to account for overall system COP/EER.
We've used a simplification for a very complex and innovative central plant that includes reversing chillers by changing the EnergyPlus IDD file included with the OS install (C:\Program Files\OpenStudio 1.10.3\share\openstudio\EnergyPlusV8-4-0\Energy+.idd) install* to allow electric boiler efficiencies above unity along with an EP measure to set the boiler efficiency to account for overall system COP/EER.
- C:\Program Files\OpenStudio 1.10.3\share\openstudio\EnergyPlusV8-4-0\Energy+.idd
We've used a simplification for a very complex and innovative central plant that includes reversing chillers by changing the EnergyPlus IDD file included with the OS install* to allow electric boiler efficiencies above unity along with an EP measure to set the boiler efficiency to account for overall system COP/EER.
