By default the EnergyPlus Input Data Dictionary only includes 20 'Zone Terminal Unit Name' fields for ZoneTerminalUnitList, which defines the terminal units connected to a single VRF condenser object.
You can edit the EnergyPlus.idd file with a text editor to add name fields to ZoneTerminalUnitList, making sure to move the semicolon to the last field:
A21, \field Zone Terminal Unit Name 20
\type object-list
\object-list ZoneTerminalUnitNames
A22, \field Zone Terminal Unit Name 21
\type object-list
A31; \field Zone Terminal Unit Name 30
\type object-list
The idd used for the EnergyPlus installation that runs from OpenStudio is located at C:\Program Files\OpenStudio 1.10.0\share\openstudio\EnergyPlusV8-4-0. If you're using a separate installation of EnergyPlus to run your idf, edit the idd for that installation.
You can edit the EnergyPlus.idd file located in the EnergyPlus installation packaged with a text editor OpenStudio (located at C:\Program Files\OpenStudio 1.10.0\share\openstudio\EnergyPlusV8-4-0 to add name fields to ZoneTerminalUnitList, making sure to move the semicolon to the last field:
\type object-list
\type object-list
\type object-list
The idd used for the EnergyPlus installation that runs from OpenStudio is located at If you're using a separate installation of EnergyPlus to run your idf, edit the idd for that installation. C:\Program Files\OpenStudio 1.10.0\share\openstudio\EnergyPlusV8-4-0.
By default the EnergyPlus Input Data Dictionary only includes 20 'Zone Terminal Unit Name' fields for ZoneTerminalUnitList, which defines the terminal units connected to a single VRF condenser object.object. \
You can edit the EnergyPlus.idd file located in the EnergyPlus installation packaged with OpenStudio (located at C:\Program Files\OpenStudio 1.10.0\share\openstudio\EnergyPlusV8-4-0 to add name fields to ZoneTerminalUnitList, making sure to move the semicolon to the last field:
\type object-list
\type object-list
\type object-list
