In 1. it is only loading the string as an IDF Object, like it would load from an IDF file.
It's loading the following Output:Variable
Output:Variable,
*, !- Key Value
Zone Mechanical Ventilation Current Density Volume Flow Rate, !- Variable Name
Hourly; !- Reporting timestep
This just means it'll apply to all objects
You can have all keys listed in the standard output file by putting a “*” in this field or you can have specific items listed by putting in a key value. If this field is left blank, it will use a * as the default (i.e., you will get all variables of Variable Name).
