Would you consider learning vim?
Folding solutions are built in.
Here is a solution for folding EnergyPlus objects
:set foldexpr=getline(v:lnum)=~'^\\s*$'&&getline(v:lnum+1)=~'\\S'?'<1':1
:set foldmethod=expr
To build equivalent folding solution to above you would have to specify fold markers using '{{{' and '}}}' similar to the way you are using '#['
Then use:
:set foldmethod=marker
I regularly work on IDF files that are 50k+. Vim works well
Hopefully there is an Emacs guru here to share their folding solution.
To build equivalent folding solution to above you your would have to specify fold markers using '{{{' and '}}}' similar to the way you are using '#['
Then use:
:set
To build equivalent folding solution to above your would have to specify fold markers using '{{{' and '}}}' similar to the way you are using '#['
Then use:
:set
