How about SetpointManager:OutdoorAirReset
It works on plant loop just fine too. The documentation is pretty confusing on this since it mentions Supply Air temperature, but a plant loop will gladly accept it too. In fact, for many of the water reset (Hot water or chilled water) in ASHRAE Appendix G, this is what you need to use.
It works on plant loop just fine too. The documentation is pretty confusing on this since it mentions Supply Air temperature, but a plant loop will gladly accept it too. In fact, for many of the water reset (Hot water or chilled water) in ASHRAE Appendix G, this is what you need to use.too.
