How are you adding the PTHP to your model? What version of OpenStudio are you using?
In version 1.9, I can assign a PTHP to the 'Zone Equipment' column of a zone in the "Thermal Zones" tab. There are no input fields to set the air inlet and outlet nodes of the PTHP fan. I can run a simulation successfully, and the resulting IDF file has these input fields automatically set by OpenStudio.
Fan:ConstantVolume,
PTHP CV Fan, !- Name
Always On Discrete 1, !- Availability Schedule Name
0.7, !- Fan Total Efficiency
250, !- Pressure Rise {Pa}
AutoSize, !- Maximum Flow Rate {m3/s}
0.9, !- Motor Efficiency
1, !- Motor In Airstream Fraction
PTHP Heating Coil Outlet Node, !- Air Inlet Node Name
PTHP Fan Outlet Node; !- Air Outlet Node Name
Adding PTHP in OpenStudio
Editing PTHP in OpenStudio
