1) The Node::addSetpointManager overloads have been deprecated in favor of addToNode. You can also determine the setpoint node associated with an SPM with the setpointNode method.
2.a) If you want to add a setpoint manager spm to a StraightComponent comp.
# assuming comp is a StraightComponent
spm.addToNode(comp.outletModelObject.get.to_Node.get)
2.b) If you have a setpoint manager, spm.
spm.setpointNode.get.nameString
3) Technically every OpenStudio ModelObject has the method object.setString(index,value) but this is entirely unsupported and we strongly discourage doing it. These methods may even become private and inaccessible in the future as it is possible to corrupt your OpenStudio model using them.
2.a) If you have a setpoint manager, spm.
2.b) If you want to add a setpoint manager spm to a StraightComponent comp.
2.a) 2) If you have a setpoint manager, spm.
4) If you want to add a setpoint manager spm to a StraightComponent comp.
4) If you want to add a setpoint manager to a StraightComponentspm comp.
assuming comp is a1) The Node::addSetpointManager overloads have been deprecated in favor of addToNode. You can also determine the setpoint node associated with an SPM with the setpointNode method.
4) If you want to add a setpoint manager to a StraightComponent...
spm.addToNode(comp.outletModelObject.get.to_Node.get) ```
2) If you have a setpoint manager, .spmwpm
