Looks like the 'S' in 'OpenStudio' needs to be capitalized in your constructor call. To add coils to an empty loop, you can get get the airloop's
supplyOutletNodeand use the theaddToNodemethod that the coil inherits from the 'StraightComponent' class.I'm pretty sure SetpointManagers aren't automatically created when you add a coil. You might be thinking of ControllerWaterCoil objects, which are created with a coil at least in the UI. Could be wrong though, do you have a source for that information?
though, do you have a source for that information?though...
