I ran the VariableRefrigerantFlow_5Zone example file and also changed the condenser type to EvaporativelyCooled. The results shown in the Component Sizing Summary using V8.4 appear correct.
The first table denotes the air-cooled simulation while the second table reflects the results of the evap-cooled simulation. The results show the values for autosized input fields.
Top one is air cooled, bottom is evaporatively cooled
The first table denotes the air-cooled air-cooled simulation while the second table reflects the results of the evap-cooled evap-cooled simulation. The results show the values for autosized input fields.
I ran the VariableRefrigerantFlow_5Zone example file and also changed the condenser type to EvaporativelyCooled. The results shown in the Component Sizing Summary using V8.4 appear correct. The first table denotes the air-cooled simulation while the second table reflects the results of the evap-cooled simulation. The results show the values for autosized input fields.
Top one is air cooled, bottom is evaporatively cooledC:\fakepath\VRF_ComponentSummary.png
I ran the VariableRefrigerantFlow_5Zone example file and also changed the condenser type to EvaporativelyCooledEvaporitivelyCooled. The results shown in the Component Sizing Summary using V8.4 appear correct. The first table denotes the air-cooled simulation while the second table reflects the results of the evap-cooled simulation. The results show the values for autosized input fields.
