Just to through in more options. If your list isn't going to be too long, you can have a string argument that expects comma separated values in it, instead of using an external file.
Then in the measure you parse it apart using code like this.
array_from_arg = arg.split(',')
Here is another option that is possible but not really recommended - The arguments section of the measure can loop through zones and make a bool argument for each zone. Then you can check the zones you want included. This isn't ideal because having a variable/unknown number of arguments for a measure can cause issues with large scale analysis, and if you have a really big model this may blow up. If intended to used only with apply measures now, then this could be ok.
Here is another option Another options that is possible but not not really recommended - recommended. The arguments section of the measure can loop through zones and make a bool argument for each zone. Then you can check the zones you want included. This isn't ideal because having a variable/unknown number of arguments for a measure can cause issues with large scale analysis, and if you have a really big model this may blow up. If intended to used only with apply measures now, then this could be ok.
Another options that is possible not not really recommended. The arguments section of the measure can loop through zones and make a bool argument for each zone. Then you can check the zones you want included. This isn't ideal because having a variable/unknown number of arguments for a measure can cause issues with large scale analysis, and if you have a really big model this may blow up. If intended to used only with apply measures now, then this could be ok.
