It sets the value for set point for room temp in cooling /heating mode likes temperature on remote of split air conditioner. When room temperature is with in setpoint range, cooling coil (compressor/aircondtioner) will be turned off
It sets the value for set point for room temp in cooling /heating mode likes temperature on remote of split air conditioner. When room temperature is with in setpoint range, cooling coil (compressor/aircondtioner) will be turned turn off
