Would need more info to really determine what's going on. Could be a number of issues:
Sizing:
- 4000 W boiler capacity is too low, so boiler operates almost all the time
- inlet and outlet temperature fields in Sizing:Plant, Boiler, and baseboard HW coil objects don't match
- you autosized flow rate for boiler, but may have hard-set flow rate for baseboard heaters
Baseboard Heaters
- UA calculations for coils may yield low heat transfer efficiency
- Availability schedule for baseboard and/or HW coils limits time of operation
My guess is that the baseboard inputs are the culprit, but all are worth checking out.
Sizing:
Baseboard Heaters
My guess is that the baseboard inputs are last point is the culprit, but all are worth checking out.
4000 W boiler capacity is too low, so boiler operates almost all the times- inlet and outlet temperature fields in Sizing:Plant, Boiler, and baseboard HW coil objects don't match
Baseboard Heaters
My guess is that the last point is the culprit, but all are worth checking out.
