As Kyle mentioned, there is a way to customize the irb startup configuration. You have to do the following (assuming Mac or Linux):
If ~/.irbrc does not exist, call touch ~/.irbrc to create it.
Then inside ~/.irbrc you can put
// I think this is the correct pathing
require "/Applications/OpenStudio 1.10.0/Ruby/openstudio.rb"
require 'irb/completion'
or what I have in my ~/.irbrc file (other than different openstudio.rb path for my dev build)
IRB.conf[:AUTO_INDENT] = true
IRB.conf[:USE_READLINE] = true
IRB.conf[:LOAD_MODULES] = [] unless IRB.conf.key?(:LOAD_MODULES)
unless IRB.conf[:LOAD_MODULES].include?('irb/completion')
  IRB.conf[:LOAD_MODULES] << 'irb/completion'
end
This will automatically load completion and openstudio everytime you call irb on command line.
As Kyle mentioned, there is a way to customize the irb startup configuration. You have to do the following (assuming Mac or Linux):following:
end
