Here is my translation of the ruby project to c#.
  • Step 1: Variables
  • Step 2: Create IDF
  • Step 3: Start RunManager
  • Step 4: Found EnergyPlus.exe File
  • Step 5: Simulation
  • Step 6: Read SQL File
       //_path must be your Folder of Saving the Project z.B. C://OpenStudio//Projects//...
        string e _runDirStr =_path + "\\run";
        string _sqlPathStr = _runDirStr + "\\EnergyPlus\\eplusout.sql";
        string _epDirStr = "C:\\EnergyPlusV8-4-0";
        string _epPathStr = _epDirStr + "\\energyplus.exe";
        string idd_pathStr = _epDirStr + "\\Energy+.idd";
        string  outputPathStr = _runDirStr;
        Path _epPath = new Path(_epPathStr);
        Path _sqlPath = new Path(_sqlPathStr);
        System.IO.Directory.CreateDirectory(_path);
        System.IO.Directory.CreateDirectory(_runDirStr);
        SimulationControl control = _model.getSimulationControl();
        control.setDoPlantSizingCalculation(true);
        control.setDoZoneSizingCalculation(true);
        control.setRunSimulationforSizingPeriods(false); //do not use DesignDays
        control.setRunSimulationforWeatherFileRunPeriods(true); //use Weatherfile
        //Export IDF
        string idf_name, osm_name;
        idf_name = "simulation_in.idf";
        osm_name = "simulation_ThesisModel.osm";
        EnergyPlusForwardTranslator translator = new EnergyPlusForwardTranslator();
        Workspace idf = translator.translateModel(_model);
        //IdfFile idf_file =  _model.toIdfFile();
        _idfPathStr = _runDirStr + "\\" + idf_name;
        osmPathStr = _runDirStr + "\\" + osm_name;
        idf.save(new Path(_idfPathStr),true);
        _model.save(new Path(osmPathStr), true);
        //Runmanager
        Path runManagerPath = new Path(_runDirStr + "\\simulation_runmanager.db");
        RunManager run = new RunManager(runManagerPath, true, false, false, false);
        ToolInfo tool = new ToolInfo(_epPath);
        Job job = JobFactory.createEnergyPlusJob(tool, new Path(idd_pathStr), new Path(_idfPathStr), _weatherFilePath, new Path(outputPathStr));
        run.enqueue(job, true);
        run.setPaused(false);
        run.workPending();
        //start Simulation
        //run.runWorkflow(new Path(job.toJSON()),new Path(_idfPath),new Path(_runDir), new Tools(),"");
        Workflow sim = new Workflow(job);
        sim.create(new Path(outputPathStr), new Path(new Path(_idfPathStr)));
        //read results
        if (System.IO.File.Exists(_sqlPathStr))
            _model.setSqlFile(new SqlFile(_sqlPath));
  • Step 1: Variables
  • Variables Step 2: Create IDF
  • IDF Step 3: Start RunManager
  • Simulation Step 6: Read SQL File
         //Export IDF
         //Runmanager
         run.workPending();
         //start Simulation
         //read results
