When you click 'Create a Measure from Template and add to My Measures' from either the 'Apply Measure Now' window or the Library pane of the Measures tab in the application, measure.xml is automatically created from the information you input in the Create New Measure window, along with measure.rb and example test files.
When you click 'Create a Measure from Template and add to My Measures' from either the 'Apply Measure Now' window or the Library pane of the Measures tab in the application, measure.xml is automatically created from the information you input in the Create New Measure window, along with measure.rb and example test files. window.
