Select "Find Components" under the Components and Measures menu item. A BCL dialog will pop up, and you'll find construction assemblies as one of the categories you can select from. You'll have to skim through several to find one that meets your needs, but once you pick and download it, it will be available in your library under the constructions tab to drag and drop into your model.
This video may help explain things.
