Are the schedules in green? If so that means they are part of a load instance inherited from the space type assigned to that space. To change the schedule go to the Space Types tab.
On the attached image the "New People load instance" object was created directly in a space. It can be deleted or altered (including changing the schedule) the other loads are from the space type.
