The shaft power (impeller) winds up as heat to the fluid. If you have specified a motor heat to fluid fraction greater than 0, additional motor heat will be added to the fluid proportional to that fraction.
! This adds the pump heat based on User input for the pump
! We assume that all of the heat ends up in the fluid eventually since this is a closed loop
ShaftPower = Power * PumpEquip(PumpNum)%MotorEffic
PumpHeattoFluid = ShaftPower + (Power - ShaftPower)*PumpEquip(PumpNum)%FracMotorLossToFluid
So there are 2 fluid heating components. One is imparted by the impeller to increase fluid pressure, the other is the motor electrical losses that may or may not heat the fluid.
The shaft power (impeller) winds up as a heat to the fluid. If you have specified a motor heat to fluid fraction greater than 0, additional motor heat will be added to the fluid proportional to that fraction.
