It depends what you want to compare and in what way? If you want to compare energy transmitted through the window then solar transmittance is definitely not the only parameter that is needed.
It depends what you want to compare and in what way? If you want to compare energy transmitted through the window then that solar transmittance is definitely not the only parameter that is needed.
