If you aren't comfortable working with zone mixing objects, is there any reason you just don't include the core zone on the air loop? Exhaust air will be deducted from return air from the core zone.
If you aren't comfortable working with zone mixing objects, is there any reason you just don't include the core zone on the air loop? Exhaust Any exhaust air will be deducted from return air from the core zone.
