If you are applying a measure as part of the simulation workflow then that measure will only run when you simulate your model. You can run the simulation, then navigate to the EnergyPlus directory and find the final simulated IDF file there. If it is not there, look up one directory and into the EnergyPlusPreProcess directory that runs right before the EnergyPlus job.
