I get those following codes from os_lib_reporting.rb file. Plesae give me some instruction for change them into SI unit of value and unit shown in result.
First type:
# EUI
    eui =  sqlFile.netSiteEnergy.get / query_results.get
    display = 'EUI'
    source_units = 'GJ/m^2'
    target_units = 'kBtu/ft^2'
    value = OpenStudio.convert(eui, source_units, target_units).get
    value_neat = OpenStudio.toNeatString(value, 2, true)
    general_building_information[:data] << [display, value_neat, target_units]
    runner.registerValue(display, value, target_units)
    return general_building_information
  end
Second type:
# summary of what to show for each type of air loop component
  def self.air_loop_component_summary_logic(component, model)
    if component.to_AirLoopHVACOutdoorAirSystem.is_initialized
      component = component.to_AirLoopHVACOutdoorAirSystem.get
      # get ControllerOutdoorAir
      controller_oa = component.getControllerOutdoorAir
      sizing_source_units = 'm^3/s'
      sizing_target_units = 'cfm'
      if controller_oa.maximumOutdoorAirFlowRate.is_initialized
        sizing_ip = OpenStudio.convert(controller_oa.maximumOutdoorAirFlowRate.get, sizing_source_units, sizing_target_units).get
        sizing_ip_neat = OpenStudio.toNeatString(sizing_ip, 2, true)
      else
        sizing_ip_neat = 'Autosized'
      end
      value_source_units = 'm^3/s'
      value_target_units = 'cfm'
      if controller_oa.minimumOutdoorAirFlowRate.is_initialized
        value_ip = OpenStudio.convert(controller_oa.minimumOutdoorAirFlowRate.get, value_source_units, value_target_units).get
        value_ip_neat = OpenStudio.toNeatString(value_ip, 2, true)
      else
        value_ip_neat = 'Autosized'
      end
      data_array = [component.iddObject.name, sizing_ip_neat, sizing_target_units, 'Minimum Outdoor Air Flow Rate', value_ip_neat, value_target_units, '']
    elsif component.to_CoilCoolingDXSingleSpeed.is_initialized
      component = component.to_CoilCoolingDXSingleSpeed.get
      sizing_source_units = 'W'
      sizing_target_units = 'Btu/h'
      if component.ratedTotalCoolingCapacity.is_initialized
        sizing_ip = OpenStudio.convert(component.ratedTotalCoolingCapacity.get, sizing_source_units, sizing_target_units).get
      else
      end
result First type:
type: # EUI
total building area
    query = 'SELECT Value FROM tabulardatawithstrings WHERE '
    query << "ReportName='AnnualBuildingUtilityPerformanceSummary' and " # Notice no space in SystemSummary
    query << "ReportForString='Entire Facility' and "
    query << "TableName='Building Area' and "
    query << "RowName='Total Building Area' and "
    query << "ColumnName='Area' and "
    query << "Units='m2';"
    query_results = sqlFile.execAndReturnFirstDouble(query)
    if query_results.empty?
      runner.registerError('Did not find value for total building area.')
      return false
    else
      display = 'EUI'
'm^2'
'ft^2'
      value = OpenStudio.convert(eui, OpenStudio.convert(query_results.get, source_units, target_units).get
     value_neat = OpenStudio.toNeatString(value, 2, 0, true)
  end
target_units)
Second type:
type:
   else
   end
   else
   end
   else
   end
  value_source_units = 'COP'
  value_target_units = 'COP'
  value_ip = component.ratedCOP.get
  description = 'Rated COP'
  data_array = [component.iddObject.name, sizing_ip_neat, sizing_target_units, description, value_ip_neat, value_target_units, '']
