Using the OpenStudio application you can just change the default interior wall construction for the default construction set for your building. There should be a construction named "Air Wall" in the library. See documentation on construction set here.
For newer videos on basic workflow checkout this playlist and the "What's New on OpenStudio 1.x" playlists here.
