Hey, now I fixed the problem with the time-data. Just the months january and December – not an entire jear, hope that this is OK (because I want to simulate just this 2 months). I can open the file in elements. I can copy the Temperature – everything works.But if I try to copy relative humidity etc. it does not work – just empty cells. I can’t copy the data in excel into the epw file – if I try: I can’t open the file in elements/Eplus. It would be so great if someone could have a look at this - I need to finish a paper and the only thing that does not work is to import that measured climate data :/.
epw file with time steps: https://www.dropbox.com/s/bwlzu6v0cx8wdd4/Weather_FinalBereich.epw?dl=0 Weather data: https://www.dropbox.com/s/bc2syn00dqkqvuq/WeatherValues.xlsx?dl=0
thank you very much!
