Hi,
I can help you with this problem. First of all can you tell me what version of EnergyPlus did you use? I would also like to see window model that you have created by using WINDOW 7 and which weather file you have used in you simulation?
Thanks, Simon
UPDATE: Have you tried to do calculations in WINDOW 7 for this system? Seems that you are missing data for back transmittance and reflectance (shading device). Is it safe to assume that your shading device is symmetrical? So if it is then you can just copy/paste yours front measured data into back transmittance (and reflectance) and then perform the simulation. Of course, edit data in WINDOW 7 and then generate IDF in WINDOW 7.
Hi,
Thanks, Simon
UPDATE: Have EDIT: Got your files. Will take a look and let you tried to do calculations in WINDOW 7 for this system? Seems that you are missing data for back transmittance and reflectance (shading device). Is it safe to assume that your shading device is symmetrical? So if it is then you can just copy/paste yours front measured data into back transmittance (and reflectance) and then perform know what the simulation. Of course, edit data in WINDOW 7 and then generate IDF in WINDOW 7.problem is.
Hi,
Thanks, Simon
EDIT: Got your files. Will take a look and let you know what the problem is.
Hi,
I can help you with this problem. First of all can you tell me what version of EnergyPlus did you use? I would also like to see window model that you have created by using WINDOW 7 and which what weather file you have used in you simulation?
Thanks, Simon
