Your EnergyPlus simulation is completing, as evidenced by this line: EnergyPlus Run Time=00hr 00min 3.05sec. The repeating warning that Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect is a known issue pertaining to non-symmetrical constructions of matched surfaces. It appears that the issue is being resolved, and the message should not have any impact on your simulation results.
Your EnergyPlus simulation is completing, as evidenced by this line: EnergyPlus Run Time=00hr 00min 3.05sec. The repeating warning that Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect is a known issue pertaining to non-symmetrical unsymmetrical constructions of matched surfaces. It appears that the issue is being resolved, and the message should not have any impact on your simulation results.
