I have export gbXML from OS to Trace 700. For some reason Trace does not import shading surfaces. Additionally if you export partitions they will appear twice in Trace. One in each room. I have used different Trace 700 version but the have the same problem.
you can see this video from Trane. It explains you the spteeps.
