You can always use a water heater as a hot water storage tank. If it is meant to be only a storage tank, heater capacity can be set to zero. In addition, if the storage tank is located in your greenhouse (and if this is also a thermal zone) you can assign it to this zone, i.e. the ambient temperatures for the tank will the zone air temperatures of the greenhouse.
You might also look here
Does this answer your question ?
