There are a couple of things to consider. The first is if the space is defined as an active storage space, because if it is, then yes it must adhere to the baseline values outlined in ASHRAE 90.1 2007 Table 9.6.1(for version 3). However, if your actual space usage is a data center then you should make those corrections in your space type (changing it to electrical/mechanical) and include the misunderstanding in your narrative accompanying the review comment.
Just make sure your space classification in baseline/proposed is consistent and include a narrative noting any changes.
Hope that helps,
Nick
