That sounds correct, are you hitting run errors when you do this? I made the loop below by dropping in one of the template systems that use a cold water loop. I deleted the chiller and then dragged the Distict Cooling to the "Drag From Library" dropzone.
That sounds correct, are you hitting run errors when you do this? I made the loop below by dropping in one of the template systems that use a cold water loop. I deleted the chiller and then dragged the Distict Cooling to the "Drag From Library" dropzone.this?
