You could write an EnergyPlus measure, but definitely a use at your own risk. This may wreak havoc with the standard reporting in OS app, PAT.
Another solution if you want to run multiple runPeriods is to create a parametric sweep on seed model, where a measure changes the RunPeriod for each design alternative.
