If you are using v3c, you can uncheck the 'Has Process Exhaust' box in the Space -> Vent & Exh tab input screen. This allows you to model the space as you would any other space, including just specifying general exhaust.. For good measure, make sure you remove any of the kitchen exhaust inputs before making this change. (remove inputs by first restoring the default is my general recommendation.
