I believe you have to either copy all the dlls from your OpenStudio install into your build directory or add the path to the OpenStudio dlls to your path. The path to copy dlls from is:
C:\Program Files\OpenStudio 1.9.0\CSharp\openstudio
Depending on what features you try to use from OpenStudio you may also need to copy some Qt plugins or other file resources.
