You can open the html file in your browser by navigating to the < model_dir >/run/6-UserScript-0/report.html. From there, if you're on a Mac at least, anything you can open in the browser you can print to a pdf. I'm not so sure about windows.
Your path might be slightly different if you have other measures in the simulation.
You can open the html file in your browser by navigating to the < model_dir >/run/6-UserScript-0/report.html. From there, if you're your on a Mac at least, anything you can open in the browser you can print to a pdf. I'm not so sure about windows.
