While this is not a eQ->E+ this is a eQ to OpenStudio geometry (surfaces, subsurfaces, space, zone) converter.
This measure is a stand-alone implementation using BTAP's equest module. Until BTAP is gemified, this is to be conisdered a hard fork of that work.
This may or may not work as this is dependent on the complexity of your model. This was created using eQuest 3.62 as the basis. So future versions may not work with this script. YMMV greatly.
The measure is contained in the following repository. Users should be able to download or git clone from this repository. This was last used successfully on OpenStudio v2.6.0
https://github.com/canmet-energy/btap
Instructions on how to use this is contained in this markdown file here
https://github.com/canmet-energy/btap/blob/master/measures_development/btap_equest_converter/README.md
Known Issues: The converter seems to have problems with special characters (accented French and Spanish characters for example). The file encoding in Ruby and eQuest make this cause some issues. Please ensure your model does not contain special characters in your model.
Enjoy!
Phylroy
Enjoy!
Phylroy
Enjoy!
Phylroy
The measure - BTAP eQuest Converter - is contained in a bit of a flux right now as we are porting some of the equest methods into a gem format. However that will not work until the gem is in the following repository. Users should next version of OpenStudio. I will update this thread once I have posted something on the BCL. On a side note, once this gem is placed in the OS ecosystem, it will be able possible to download or git clone from this repository. This was last used successfully on create, in a limited capacity, DOE2.x measures using the OpenStudio v2.6.0 SDK.
Enjoy!
Phylroy
The measure - BTAP eQuest Converter - is in a bit of a flux right now as we are porting some of the equest methods into a gem format. However that will not work until the gem is in the next version of OpenStudio. I will update this thread once I have posted something on the BCL. On a side note, once this gem is placed in the OS ecosystem, it will be possible to create, in a limited capacity, DOE2.x measures using the OpenStudio SDK.
