Try adding an Output:Diagnostics object to DisplayAllWarnings, which will add more detail to the ERR file.
Some other thoughts:
  • Check the ERR file for more detail about the error(s)
  • If you're using OpenStudio make sure the model has a weather file (may need to re-select it).
