Hi @iasonas_fng, sorry for your troubles. When working with OpenStudio you only need to save your OSM file, you do not need to save the SKP file. When you open SketchUp you can go to the OpenStudio menu and choose open OSM, re-opening a SKP file linked to an OSM sometimes causes problems. I am a little unsure what you mean by "Selecting Save As or Export from the OpenStudio menu doesnt seem to do anything so I start with Save As .skp model from the File menu", can you expand on that? When you choose "Save" or "Save As" from the OpenStudio model it should prompt you for where you want to save your OSM file if you have not already saved it.
