This warning is telling you that you haven't referenced the SOLARCOLLECTOR:UNGLAZEDTRANSPIRED in your air system. Typically, it should appear in the outdoor air system. You can see how it's referenced in this example file.
This warning is telling you that you haven't referenced the SOLARCOLLECTOR:UNGLAZEDTRANSPIRED in your air system. Typically, it should appear in the outdoor air system. You can see how it's referenced in this example file.system.
