Currently we support Exterior Lights but not other Exterior equipment. There are a few options for now.
- First is just to model as lights, which you did, but that will report as exterior lighting as you found out
- You could make a dummy zone that isn't included in the building area and sits somewhere away from your main building, and add there as an internal load.
- The third option is to add an EnergyPlus measure to your workflow to add an Exterior:FuelEquipment object to your model.
