Make sure you update the version in all of the EnergyPlus input file.idf files referenced.
For example, in the .ini you could have two idf files in there:
Simulation { Files { Template { File1 = singleZonePurchAir_template.idf; } Input { File1 = singleZonePurchAir.idf; } Log { File1 = singleZonePurchAir.err; } Output { File1 = singleZonePurchAir.eso; }
In which case you'd need to modify the singleZonePurchAir.idf and the singleZonePurchAir_template.idf.
Make sure you update the version in all of both the EnergyPlus input file.idf files referenced.
For example, in file and the template .ini you could have two idf files in there:
