I think you can create every layer for the glazing under under glazing windows materials. Then if you go to construction tab you an create a new external windows construction and add the layers that you created from my model tab from your right side. Another option is to create a Simple Glazing System Windows Material and input the total VLT and SHGC from the triple window. If you have those properties.
