Looks like you are using the Legacy OpenStudio plugin which works with "IDF" vs. "OSM" files. The help menu opens a local html based reference guide and tutorial.
Have to go back to old YouTube video before we had a microphone to see the legacy plugin in action.
The other version you are seeing is from the new OpenStudio that works with "OSM" files. If this is what you want you can install it on top of the legacy plugin already on your machine. It will include stand alone applications as well as a SketchUp Plugin.
