I typically avoid creating loose geometry when drawing exterior doors and windows.
I double-click on the exterior space to select it, and then draw windows on the surfaces...
Double-click to select space: image description
If you have the space selected when you draw windows on the surfaces, the OS plugin should automatically create the appropriate subsurface without the need to project loose geometry.
