A simple way to update your Design Days would be to
  • create an OpenStudio file with the data from appropriate ddy-file loaded.
  • Then export the osm-file e.g. to file aux.idf
  • Then copy manually the design days in IDF Editor from aux.idf to your idf file.
  • Run test simulation and check whether target temperatures etc. remain within desired bounds.
  • If OK, you will probably not need 12 sizing periods.
