I am not quite sure if that is what you are asking but you could also use the ZoneVentilation:DesignFlowRate object set up correctly.
I am not quite sure if that is what you are asking but you You could also use the ZoneVentilation:DesignFlowRate object set up correctly.
You could also perhaps use the ZoneVentilation:DesignFlowRate object set up correctly.object.
You could also perhaps use you the ZoneVentilation:DesignFlowRate object.
