If you only have multiple IDF files and multiple Weather Files and you want to run every combination possible, you can do that in EPlaunch by going to the tab 'Group of Input File'.
You'll have to select all the IDF files first, then all the weather files. You can then review and add new simulations or delete some of the combination proposed. Tab 4 ask you where you want to output it. You can easily set it up to output to a folder like 'Input file\Weather File' or something like this.
I suggest trying it out with a limited numbers of combinations first to make sure you're getting what you want before letting it run for hours or days.
You might want to take a look at these two threads as well.
