Here's how to do it in the meantime in case anyone has an urgent matter:
- Create a boiler plant loop with the boiler on the supply side and the WaterHeater:Mixed (called
tank) on the demand side - Create a secondary loop, where we want to put the tank on the supply side. Let's call this
DHW Plant Loop
Once your model is loaded
# Get storage tank
tank = model.getWaterHeaterMixedByName('Storage Tank').get
# Get Secondary loop
dhw_loop = model.getPlantLoopByName('DHW Plant Loop').get
# Add the tank on the supply side of the secondary loop
dhw_loop.addSupplyBranchForComponent(tank)
Then save your model, and when you reopen it the tank will be properly connected.
Edit
Here is a link to a measure on BCL that creates a WaterHeater:Mixed and sets the source and use sides.
DHW Plant Loop
# Get storage tank
Edit
Here is a link to a measure on BCL that creates a WaterHeater:Mixed and sets the source and use sides.WaterHeater:Mixed
DHW Plant Loop
# Get storage tank
Edit
