Trying running the diagnostic script seen here, and see if the file it saves can be exported without crashing. I don't think the version of SketchUp or OpenStudio is the issue. The intersect is probably doing something bad to the file. If the diagnostic script doesn't work well, you may consider manually or selectively intersecting. You can intersect a selection vs. the entire model.
