You didn't specify, or hard-assign, a construction to your glass door.
OpenStudio is looking at the default Construction Set it should be using (chances are you defined one at the building level), and it's not finding one, so the glass door ends up with no construction and the E+ simulation crashes.
By default, I don't think the construction set templates from OS usually have a construction for glass door.
Here is the Large Hotel template, notice that "Glass Doors" is empty.
Large Hotel
So either fill this field in the construction set, or hard-assign a construction directly to the glass door.
OpenStudio is looking looked at the default Construction Set it should be using (chances are you defined one at the building level), and it's not finding one, so the glass door ends up with no construction and the E+ simulation crashes.
Here here is the Large Hotel template, notice that "Glass Doors" is empty.
Large Hotel
